Autor Subiect: Cum sa emigrezi in CANADA  (Citit de 8580 ori)
  • Thanked: 239 times
« : 05.Iul.2010, 01:36:16 p.m. »
P.S. Deschidem un topic dedicat emigrarii in CANADA?  :->
Deschidem. Poate vom ajunge sa deschidem si-o filiala suzuki-club.ca  :D
Pornind de la cele de mai sus...am deschis acest topic.
Pentru inceput trebuie sa vezi daca esti eligibil (cat de cat) pentru a aplica. Lucru asta il poti face aici (jos in pagina, Begin the Evaluation)
Re: Cum sa emigrezi in CANADA
« Răspuns #1 : 08.Iul.2010, 10:50:41 a.m. »
N-a incercat nimeni? :->
« Răspuns #2 : 08.Iul.2010, 11:07:15 a.m. »
Eu am facut testul pentru noi si am obtinut calificativ pozitiv.  :)  Da tot nu cred ca o sa aplic vreodata, e prea departe Canada...
Offline WayOfLife
  • Mesaje postate: 2846
« Răspuns #3 : 08.Iul.2010, 11:20:07 a.m. »
L-am facut eu si am primit asta:
Your candidate profile is interesting. Nontheless, in light of the information that you have submitted, you do not currently meet Québec's selection criteria. You or your spouse do not possess adequate knowledge of the French language. We recommend that you, along with your spouse if applicable, take French language courses. The Ministère de l'Immigration et des Communautés culturelles has signed agreements to teach French with certain Alliances françaises and French language teaching institutions.
We invite you to fill out a new online Preliminary Evaluation for Immigration once you have acquired sufficient knowledge of the French language.
Thank you for your interest in Québec.
Concluzie...trebuie sa ne apucam de francais!
Offline krantz
« Răspuns #4 : 08.Iul.2010, 01:36:21 p.m. »
SX4 S-Cross AllGrip 1.4 Boosterjet
SX4 1.9TD 4WD Gri metalizat
Offline Swithin
  • Mesaje postate: 256
« Răspuns #5 : 18.Oct.2010, 10:02:46 p.m. »
Un site lansat de curand de catre niste oameni care stiu ce vorbesc:
http://www.emigrare.ca/
Grow up.
« Răspuns #6 : 13.Nov.2011, 02:15:38 a.m. »
S-au pierdut multe din topicul asta odata cu "defectul" serverului dar...in seara asta am gasit ceva interesant sau nu..
« Răspuns #7 : 06.Dec.2011, 06:48:18 p.m. »
Pentru cine avea ganduri si n-a apucat sa faca nimica..mai bine sa se puna pe pauza ...
Toutes les demandes d'immigration travailleurs qualifiés au Québec doivent être accompagnée d'un examen de langue, effectif le 5 décembre 2011...
Iar examenele sunt unele belea..se tin in RO, la insititut pe una bucata PC, iar oralul se inregistreaza si se trimite la Paris unde este analizat si notat  >:)
Preturile...sunt ok
TCF   épreuves obligatoires seules   90 €
épreuves obligatoires + 1 épreuve facultative (expression écrite ou expression orale)   130 €
épreuves obligatoires + 2 épreuves facultatives (expression écrite et expression orale)   170 €
TCF Québec   (réservé à l’usage exclusif des candidats déposant un dossier d’immigration au Québec)   130 €
TCF- DAP   (TCF- Diplôme d’admission préalable)   130 €
TCF – RI   (TCF – Relations internationales : version du TCF conçue pour les besoins d’organismes internationaux ou d’organisations intergouvernementales (ONU, OCDE, Commission européenne...), écoles de diplomatie et/ou de relations internationales).)   170 €
Bafta!
Offline Iahim
  • Mesaje postate: 345
  • Suzeta Splash 1,2
« Răspuns #8 : 06.Dec.2011, 10:15:15 p.m. »
Ceva de Aussie?....
« Răspuns #9 : 06.Dec.2011, 10:50:45 p.m. »
Acolo oricum dura mult..si era necesar din start IELTS-ul. Te tenteaza? B-)
