Autor Subiect: Subwoofer aftermarket ?  (Citit de 14472 ori)
Offline Geo (SX4Owner)
  • Mesaje postate: 443
  • Happy that i'm not anymore SX4Dreamer
Re: Subwoofer aftermarket ?
« Răspuns #60 : 08.Feb.2010, 10:24:11 p.m. »
In locul ceasurilor de deasupra bordului la vechiul model sau in locul gps-ului daca vorbim de modelul american.
SAYURI, o gheisa plina de talente
  • Thanked: 239 times
« Răspuns #61 : 08.Feb.2010, 11:39:09 p.m. »
Vorbim de modelul nou SX4, varianta europeana. Ei au facut o fapta buna, la imagine, adaugand un difuzor de bas fara a schimba insa unitatea audio.
« Răspuns #62 : 09.Feb.2010, 11:46:38 a.m. »
Ar fi buna o schema despre legaturile la boxe pentru noul model.
« Răspuns #63 : 09.Feb.2010, 12:08:05 p.m. »
Exista doar mufa Suzuki ca la vechiul model.
(Am montat la Autonet o navigatie dedicata modelului SX4 si are fix aceeasi mufa, aceeasi diagrama)
Car Radio Battery Constant 12v+ Wire: White/Red
Car Radio Accessory Switched 12v+ Wire: Blue/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Black/Yellow
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: White/Green
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): Yellow/Red
Right Front Speaker Negative Wire (-): Yellow/Black
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Light Green/Black
Right Rear Speaker Positive Wire (+): Gray/Red
Right Rear Speaker Negative Wire (-): Gray
« Ultima Modificare: 09.Feb.2010, 12:18:44 p.m. de cristyyy2003 »
Offline Sakura77
« Răspuns #64 : 09.Feb.2010, 02:37:39 p.m. »
SI DECI LA NOUL MODEL UNDE E LEGAT WOOFERUL, sau boxa din bord ?
Post Merge: 09.Feb.2010, 02:42:49 p.m.
cine poate sa specifice ce tip este instalatia audio  la SX4 din 2008, ma refer la marca, putere aparat si boxe instalate in masina, precum si marimea/adincimea  boxelor
nu de alta dar nu vreau sa ma apuc sa demontez fete usi doar sa vad ce tip de boxe imi trebuie, apoi sa le montez la loc, sa cumpar boxele si sa desfac iar fetele de la usi ca sa le montez
MULTUMESC !
« Ultima Modificare: 09.Feb.2010, 02:42:49 p.m. de Sakura77 »
Sx4 1.6 GS 4WD
« Răspuns #65 : 09.Feb.2010, 11:18:34 p.m. »
Mi-e greu sa cred ca au legat boxa centrala la una din boxele din fata fie stanga sau dreapta :-/.
Un electronist cu suzuki pe forum avem?  :)
« Răspuns #66 : 09.Feb.2010, 11:33:10 p.m. »
Ti-e greu sa crezi? Da-mi zece minute la tine in masina si ai unitatea centrala demontata iar tu vi cu diagrama firelor si vezi daca exista vreunul in plus, merge?  >:)
« Răspuns #67 : 09.Feb.2010, 11:36:28 p.m. »
Chiar pe Sayuri vrei sa o demontezi, =)); Pai si firele de la boxa centrala la ce iesire "este" legate?
« Răspuns #68 : 09.Feb.2010, 11:52:23 p.m. »
Glumesc. Eu ti-am zis pe ce imi bazez afirmatiile.
« Răspuns #69 : 10.Feb.2010, 09:09:44 a.m. »
Atat timp cat le-ai desfacut cu manuta ta :clap:, te cred, dar cand o sa am timp (vreodata in secolul asta) as fi curios sa il desfac sa vad unde ar fi legate cele pentru sub. :-/
