Autor Subiect: Inchidere centralizata jimny  (Citit de 12166 ori)
Offline nick 85
  • Mesaje postate: 79
« : 10.Dec.2014, 03:10:02 p.m. »
Am schimbat bateria la cheie si acum nu mai merge inchiderea centralizata de la buton. Merge numai manual. Stie cineva ceva? Va rog.
Offline VAXXi
Re: Inchidere centralizata jimny
« Răspuns #1 : 10.Dec.2014, 03:24:14 p.m. »
Inchiderea centralizata inseamna ca inchizi usa soferului si se inchid si celelalte 2. Ce intrebi tu este "inchidere de la distanta" :)
Ai inchidere de la distanta din fabrica (cu buton pe cheie) sau telecomanda separata (caz in care inchiderea se face din alarma aftermarket) ?
Offline nick 85
« Răspuns #2 : 10.Dec.2014, 04:09:42 p.m. »
Da. Este cheia originala cu 2 butoane. Nu mai merge de la buton-distanta. Merge numai manual inchiderea centralizata. Acum vreo 2-3 ani am schimbat bateria si tot asa am patit. A rezolvat-o un baiat de la un atelier de reparatii televizoare care s-a mutat acum. A facut ceva configurare cu ea in contact dar nu stiu procedeul.
Offline VAXXi
« Răspuns #3 : 10.Dec.2014, 04:23:31 p.m. »
"De pe net":
1) Confirm that the vehicle is the following conditions.
• All doors are closed.
• Ignition key is out of ignition switch.
• Driver side door is unlocked.
2) Disconnect negative (-) cable from battery.
3) After 30 seconds, perform the following procedure within 60
seconds.
a) Connect negative (-) cable to battery.
b) Operate driver side door knob switch from lock to unlock.
c) Push “LOCK” button on transmitter and confirm that are
operated from lock to unlock.
d) Push driver side door knob switch to lock position.
e) Push “LOCK” button on transmitter twice and confirm that
all doors are operated from unlock to lock. With this, code
registration is completed.
sau ia manualul de service, s-ar putea sa fie procedura acolo.
Offline nick 85
« Răspuns #4 : 10.Dec.2014, 06:43:55 p.m. »
Nu merge. Sau poate nu inteleg eu clar procedura cu engleza pe care o stiu eu.
1. Confirmati ca vehiculul este in urmatoarele conditii:
Toate usile sunt inchise( asta inseamna inchise sau blocate?)
Cheia este scoasa din contact.
Usa soferului este deblocata( restul trebuiesc blocate sau nu?)
2. Deconectati borna - de la baterie.
3. Dupa 30 de secunde urmati urmatoarea procedura in 60 de secunde:
a) Conectati borna - de la baterie
b) Operate driver side door knob switch from lock to unlock.( operati butonul de la usa din pozitia blocat in pozitia deblocat-dar cand a fost butonul pe pozitia blocat? ca sus scrie ca usa soferului este deblocata. eu aici nu inteleg.)
c) Apasati butonul blocare de pe telecomanda si confirmati ca este operat din pozitia blocare in deblocare- aici iara nu inteleg contextul daca mai sus zice ca usa sa fie deblocata.
d) Apasa butonul de la usa in pozitia de blocare.
e) Apasa butonul de blocare de pe telecomanda de 2 ori si confirma ca este operat din deblocare in blocare. Cu aceasta codul de inregistrare este complet.
  Si nu specifica nimic de butonul de deblocare de pe telecomanda.
Offline nick 85
« Răspuns #5 : 10.Dec.2014, 06:45:02 p.m. »
Nu m-as stresa foarte mult daca nu as folosi de 10-20 de ori pe zi inchiderea de la buton.
Offline >pexic<
« Răspuns #6 : 10.Dec.2014, 07:00:59 p.m. »
Usa soferului este deblocata( restul trebuiesc blocate sau nu?)  de ce crezi ca nu zice nimic despre celelalte usi daca oricum ele se blocheaza/deblocheaza automat de la usa soferului ??
Offline nick 85
« Răspuns #7 : 10.Dec.2014, 09:40:43 p.m. »
M-am gandit ca a patit cineva la fel si ma poate ajuta cu ceva concret. Voi nu v-ati schimbat bateria de la cheie niciodata?
Offline >pexic<
« Răspuns #8 : 11.Dec.2014, 03:18:30 a.m. »
ba am schimbat bateria, si cu ocazia aia am si curatat butoanele si contactele bateriei, le-am umplut de spray contact.
Offline nick 85
« Răspuns #9 : 11.Dec.2014, 02:45:03 p.m. »
Si eu tot asa am facut. Am curatat tot, montat baterie noua si am ramas fara inchidere de la buton.
