Autor Subiect: Recunoastere cheie inchidere centralizata  (Citit de 3847 ori)
Offline paunica.mihail
  • Mesaje postate: 14
« : 17.Iun.2013, 10:48:11 p.m. »
Salut! Bateria de la cheia mea dadea semne de imbatranire asa ca am scos-o si am cumparat una identica.Din cate am inteles daca bateria este scoasa mai mult de 1-2 min din cheie aceasta va pierde memoria(codul) pentru inchiderea centralizata. Acum nu imi merge sa descui usile din cheie dar centralizata merge bine (cu cheia in usa sau de la butonul din interiorul masinii). La opel stiu ca trebuia sa pui cheia in contact.. sa apesi butonul de blocare si sa il tii apasat si se seta singura,insa la mine nu a mers. Aveti vre-o idee cum se poate remedia problema ?
Offline hodoroncktronck
Re: Recunoastere cheie inchidere centralizata
« Răspuns #1 : 19.Iun.2013, 03:25:53 p.m. »
Am gasit asta in manualul de service al masinii la pagina 998:
"Change of Signal Mode
1) Make sure that all doors are closed and ignition key is out of
ignition switch.
2) Perform the following procedures within 10 seconds.
a) Insert ignition key to ignition switch.
b) Turn ignition switch to “ACC” position, turn ignition switch to
“OFF” position, and then pull off ignition key from ignition
switch.
c) Repeat step b).
d) Turn ignition switch to “ACC” position, turn ignition switch to
“OFF” position, and then push “UNLOCK” button on transmitter
more than three times.
3) Confirm that either hazard warning light or interior light flash
once. With this, change of signal mode is completed."
Poate te ajuta cu ceva.  :)
« Răspuns #2 : 19.Iun.2013, 09:39:14 p.m. »
Multumesc dar nu a mers .. ACC inseamna prima pozitie a contactului (cea de accesorii) ? ..
« Răspuns #3 : 19.Iun.2013, 10:02:49 p.m. »
Am gasit asta .. Aia era pentru altceva.. Acum ma duc sa incerc :))
If transmitter or door lock controller is replaced with new one, register
code as follows.
ignition key cylinder
2) Open driver side door.
3) Turn ignition switch to ON position, and then remove ignition
key from ignition key cylinder within 10 seconds after that.
4) Push and release driver side door switch (1) at 3 times by
hand within 20 seconds after removing ignition key from ignition
key cylinder.
5) Turn ignition switch to ON position, and then remove ignition
6) Push “UNLOCK” button (2) on transmitter (3) and confirm
that all doors are operated from lock to unlock.
With this, code registration is completed.
« Răspuns #4 : 19.Iun.2013, 10:50:11 p.m. »
Am incercat si asta.. Nu merge din pacate.
Offline gnis
  • Mesaje postate: 1
« Răspuns #5 : 14.Oct.2013, 07:21:48 p.m. »
ai rezolvat?
« Răspuns #6 : 09.Dec.2013, 11:37:53 p.m. »
Din pacate nu. Ai vre-o idee ?
