Autor Subiect: Vand pachet Woofer Magnat 1000 w RMS 1 ohm  (Citit de 1488 ori)
Offline Aiurica
  • Mesaje postate: 90
  • pasionat
« : 07.Mai.2012, 10:26:39 a.m. »
Vand Subwoofer Auto Magnat450 w RMS Statie Magnat RX Mono 1000W RMS
Pachet de bass format din:
Amplificator Magnat RX Mono 1000W RMS:
- amplificator auto mono
- putere:
- 4 ohmi: 1 x 500W RMS (1 x 1000W max)
- 2 ohmi: 1 x 700W RMS (1 x 1400W max)
- 1 ohm: 1 x 1000W RMS (1 x 2000W max)
- Raspuns in frecventa 5 - 250 Hz
- THD < 0, 05 % (1 kHz)
- filtru LPF variabil 40- 250 Hz, 12 dB
- filtru subsonic variabil 10- 40 Hz, 12 dB
- Bass boost variabil 0- 15 dB la 45 Hz
- dimensiuni: 450 x 50 x 261 mm
- intrari / iesiri RCA aurite
- 4 sigurante fuzibile tip maxi
- control volum remote (telecomanda pe fir)
Subwoofer Magnat 450W RMS
- diametru difuzor: 30cm
- putere RMS: 800W
- putere maxima: 450W
- incinta solida din MDF
Pret 250 Eur
c4, 110 cp, alb cu parbrizu netunat :)
