Autor Subiect: sistem aprindere SX4  (Citit de 7273 ori)
Re: sistem aprindere SX4
« Răspuns #10 : 27.Ian.2011, 12:57:41 p.m. »
poate senzorii de citit arborii (care o fi ei) s-au injumatatit
Pai aia tot 2 sint - CKP si CMP  (pag. 153 respectiv 155 din manual)
The CMP sensor located on the transmission side of cylinder head (for M16 engine model) or timing chain cover (for
M15 engine model) consists of the signal generator (magnetic sensor) and signal rotor (intake camshaft portion (for
M16 engine model) or exhaust camshaft timing sprocket (for M15 engine model)).
The signal generator generates reference signal through slits in the slit plate which turns together with the camshaft.
Reference signal
The CMP sensor generates 6 pulses of signals each of which has a different waveform length while the camshaft
makes one full rotation. Refer to “Inspection of ECM and Its Circuits: ”.
Based on these signals, ECM judges which cylinder piston is in the compression stroke and the engine speed.
... despre CKP n-am gasit proza :(
