Autor Subiect: Eroare P0191  (Citit de 6780 ori)
Offline Mariise
  • Mesaje postate: 2
    • Focsani
Eroare P0191
« : 17.Nov.2015, 09:04:33 p.m. »
Salutare! Detin un GrandVitara 2.0TD (cod motor RHZ) iar de ceva vreme ma necajeste o eroare: P0191(asa mi-a dat pe tester).
Masina intra in "limp mode"(nu se mai tureaza peste 2500 si nu mai intra turbina) iar motorul la relantii parca merge in 3 pistoane si scoate un zgomot ciudat. I-am schimbat senzorul de presiuna rampa combustibil dar comportamentul a ramas acelasi.
Va pot spune ca masina are toane si nu face tot timpul asa. Cand apare defectul o opresc in mers, dau o cheie si isi revine pana cand apare iar(unerori in 5-10 min, alteori la cateva zile).
As fi recunoscator daca mi-ati da cateva sfaturi la problema asta!
  • GrandVitara
Online Leutz
Re: Eroare P0191
« Răspuns #1 : 18.Nov.2015, 02:07:58 p.m. »
Uite aici ceva ce te poate ajuta: http://www.bba-reman.com/forums/Topic87926-1-1.aspx
Prima pagina a topicului deja are o gramada de informatii. Nu m-am mai uitat la restul. Mi-au atras in special atentia urmatoarele postari:
"P0191 - Fuel Rail Pressure Sensor Circuit Range/Performance.
That code is in no way an instruction to change any component.  It indicates that the rail pressure was reported as being outside the expected values.
Guesswork will get you nowhere on a complex system like an HDi.  Either you know them - or you leave them be.
When you get that code on an HDi you carry out an injector leak-off rate test - the results of that are the next crucial bit of info."
"From the info you have provided i would be guided to the seized in injector. as the corrosion builds between the injector and head, it tends to have a compressing/squeezing effect over the most critical area which houses the spray nozzle, because the working clearance in the injector is so small any change in size can cause the injector to malfunction. now comes the bad part, on many alloy head engines the corrosion that forms in the aforementioned area is equivalent to it being permanently welded and many times the head or engine has to be scrapped. there has been a release of heavy duty injector pullers for sale, if the injector wont move with a couple of swings with one dont waste time, start looking for a head or engine. there have been many suggestions ref using coca cola etc forget it ive tried them all and none work. i also had one head where i had the injectors spark eroded out but that cost £200.00 more than a new head from main dealer !.   "
The following users thanked this post: Mariise
Offline Mariise
  • Mesaje postate: 2
    • Focsani
Re: Eroare P0191
« Răspuns #2 : 18.Nov.2015, 06:48:39 p.m. »
Multumesc! O sa incerc si pe "pistele" care s-au scris in topicul acela
  • GrandVitara
Offline Nicushumi
  • Mesaje postate: 2
    • Bucutesti
Re: Eroare P0191
« Răspuns #3 : 19.Sep.2020, 10:22:36 a.m. »
Salutare aceeiasi problema o am și eu oare cum pot scapă de aceasta problema i-am schimbat rampa și cu senzorul dar la fel
  • Grand vitara
