Autor Subiect: USB "la liber" - USB UNLOCK  (Citit de 4453 ori)
  • Thanked: 239 times
« : 26.Dec.2010, 11:05:27 p.m. »
Pentru ca i s-a deschis maica mii apetitul de filme si cum n-am bani de cumparat media playere sau mai stiu eu m-am apucat de "sapat" pe net si am gasit, pentru LCD ei, un LG urmatorul tutorial:
In order to activate the USB port in the LG LCD TV models mentioned above, you need to be on Firmware version 3.15 of your LCD TV. Therefore it is important to check what firmware version you have before applying the hack. You can do that by pressing MENU on the remote, then SETUP and then go to DIAGNOSTICS.
If you’re on V 3.15 then you’re good to go! If you’re on versions above 3.15 then you need to follow the steps mentioned in this wiki in the section Above 3.15
Before we start:
This hack will flash your firmware which will/might void your warranty. If you follow the guide and read it thoroughly you’ll be just fine. However if you’re uneasy at trying this there’s a way to accomplish this with a InfraRed (IrDA) hack. If you want to go that way please follow the IR Hack section of the wiki.
Still here? WOW! You’re a brave soul! OK then, let’s continue.
After you’ve made sure you’re on v. 3.15 here’s the steps required to enable USB playback:
1. Press and hold OK on the remote and on the TV set and wait for 5 seconds.
2. When asked for password enter this password: 0000
3.After you entered the service menu go to Tool Option 3 as shown below
4. After you’ve entered Tool Option3, change these values
EMF (JPEG,MP3) to 1
Divx to HD
as shown below:
DON’T CHANGE ANYTHING ELSE, AS YOU CAN BRICK YOUR TV !
YOU MIGHT FEEL BRAVE ENOUGH TO PLAY WITH THE OTHER SETTINGS, BUT YOU WILL BRICK YOUR TV AND END UP WITH A BRICKED TV SET. ONLY CHANGE WHAT IS SHOWN ABOVE !
That’s it! Now you can go back and when you press MENU on your remote you’ll see that a new USB item in your menu has appeared.
There you go! Enjoy your new LCD TV & Media Player.
Above v. 3.15
If you see in your DIAGNOSTIC screen that your LCD TV has a firmware version above v.3.15 then this hack won’t work with the MENU combination. You will need to downgrade the firmware to version 3.15 initially so that you can enable the hack with the combination from above and then you can upgrade and the hack will still be functional.
Before we start, if you’re above V3.15 the first suggestion is to try the IR Hack , which is safer and doesn’t void your warranty.
If however for some reason you can’t find a remote, then you can follow the guide below.
If you have V3.48 or V3.47 on your DIAGNOSTIC screen don’t try to downgrade with this method as you will brick your TV! You have been WARNED!
Simply upgrade first to V3.55 and then downgrade to V3.15.
YOU CAN only downgrade with this method if your firmware is V3.24, V3.37, V3.40,V3.55 AND V3.63 (which is the latest firmware)
A incercat cineva asa ceva? Maine trec pe la ea sa verific versiunea de software  B-)
« Ultima Modificare: 26.Dec.2010, 11:07:36 p.m. de cristyyy2003 »
Re: USB "la liber" - USB UNLOCK
« Răspuns #1 : 26.Dec.2010, 11:05:55 p.m. »
Traducerea in RO de Google Translate:
Traducere din Engleză în Română
În scopul de a activa portul USB în modele de televizoare LCD LG menţionate mai sus, trebuie să fie pe versiunea Firmware 3.15 din TV LCD. Prin urmare, este important să se verifice ce versiune firmware aveti inainte de a aplica hack. Puteţi face acest lucru prin apăsarea MENU de pe telecomanda, apoi SETUP si apoi du-te la diagnosticarea.
Dacă sunteţi pe V 3.15, atunci esti bine să plec! Dacă sunteţi pe versiunile de mai sus 3.15, atunci ai nevoie să urmaţi paşii menţionate în acest wiki, în secţiunea de mai sus 3.15
Înainte de a începe:
Acest hack va flash firmware-ul, care va / ar putea anula garanţia. Dacă urmaţi ghidul şi citiţi-l bine vei fi bine. Cu toate acestea, dacă sunteţi neliniştită la încercarea de aceasta există o modalitate de a realiza acest lucru cu un infraroşu (IrDA) hack. Dacă doriţi să mergeţi în acest fel vă rugăm să urmaţi secţiunea IR Hack din wiki.
Încă aici? WOW! Eşti un suflet curajos! OK, atunci, să continuăm.
După ce aţi făcut-vă că sunteţi pe v. 3.15 aici e măsurile necesare pentru a permite redarea USB:
1. Apăsaţi şi ţineţi apăsat OK pe telecomandă şi pe televizor şi aşteptaţi 5 secunde.
2. Când a fost întrebat de parolă introduceţi această parolă: 0000
3.After aţi intrat în meniul de serviciu merge la opţiunea Instrumentul 3 aşa cum se arată mai jos
4. După ce aţi introdus Tool Option3, modifica aceste valori
EMF (JPEG, MP3) la 1
DivX HD la
după cum se arată mai jos:
NU schimba nimic altceva, după cum puteţi BRICK TV DUMNEAVOASTRĂ!
-Ar putea simţi destul de curajos să joace cu setările ALTE, dar va BRICK TV DUMNEAVOASTRĂ şi se încheie cu un televizor bricked. NUMAI schimba ceea ce este prezentat mai sus!
Asta e! Acum puteţi să mergeţi înapoi şi atunci când apăsaţi MENU de pe telecomanda dumneavoastră veţi vedea că un nou element USB din meniul dumneavoastră a apărut.
Acolo te duci! Bucuraţi-vă de noul LCD TV & Media Player.
De mai sus v. 3.15
Dacă vedeţi în ecranul DIAGNOSTIC dumneavoastră că televizorul LCD are o versiune de firmware v.3.15 de mai sus, atunci acest hack nu va funcţiona cu o combinaţie MENU. Va trebui să downgrade firmware-ul la versiunea 3.15 iniţial, astfel încât să aveţi posibilitatea să activaţi hack cu combinaţie de mai sus şi apoi puteţi să faceţi upgrade şi hack va fi în continuare funcţional.
Înainte de a începe, dacă sunteţi de mai sus V3.15 Prima sugestie este de a încerca Hack IR, care este mai sigur şi nu anula garanţia.
Dacă, totuşi, pentru anumite motive nu puteţi găsi o telecomandă, atunci puteţi urma ghidul de mai jos.
Dacă aveţi V3.48 sau V3.47 pe ecran DIAGNOSTIC dvs. nu încercaţi să downgrade cu această metodă, după cum veţi caramida TV! Aţi fost avertizat!
Pur şi simplu upgrade primul la V3.55 şi apoi downgrade la V3.15.
downgrade POTI numai cu această metodă dacă firmware-ul este V3.24, V3.37, V3.40, V3.55 SI V3.63 (care este cel mai recent firmware)
« Răspuns #2 : 27.Dec.2010, 09:47:32 a.m. »
Mda... Pica varianta pe USB :(
Seria LG de o are ea nu are optiunile descrise mai sus in meniul ascuns :(
Offline ..::Khaos::..
  • Mesaje postate: 5819
  • Thanked: 3 times
« Răspuns #4 : 27.Dec.2010, 11:01:34 a.m. »
N-am inteles ceva: TV-ul ei avea USB insa nu putea fi folosit?
« Răspuns #5 : 27.Dec.2010, 11:55:22 a.m. »
Sunt foarte multe televizoare care au USB dar portul este blocat de producator ca sa justifice diferenta de pret dintre cele care pot citi poze, filme etc pe usb si cele care nu pot.
Am gasit pe net destui care au reusit sa faca treaba asta...numai ca LCD ei este cam basic asa si ....nu are hardware necesar pentru asa ceva.
Asta este :(
  • Mesaje postate: 15103
  • Thanked: 3866 times
« Răspuns #6 : 27.Dec.2010, 12:07:42 p.m. »
Inseamna ca portul acela USB este doar o mufa inactiva ?
« Răspuns #7 : 27.Dec.2010, 12:09:16 p.m. »
Mai sap...tot ce am gasit pana acum este ca hardwareul LCD-ul nu stie sa ruleze filme ori altceva :(
« Răspuns #8 : 27.Dec.2010, 12:27:54 p.m. »
Banuiesc ca vorbesti de seriile LH (2000-7000) sau PJ (350-550) de la LG. Astea sunt seriile comercializate la noi si la care ar fi posibila chestia asta. Ideea este urmatoarea: televizoarele din aceste serii sunt identice, diferentele dintre ele fiind niste limitari la nivel software - in special la media player.
Cel mai bine ar fi sa verifici ce posibilitati exista pentru modelul specific de televizor, pentru ca s-ar putea ca meniul service sa nu poata fi accesat (cum e cazul lui PJ350).
Multa bafta!
Offline Leutz
« Răspuns #9 : 27.Dec.2010, 03:16:29 p.m. »
Unele au port USB doar pentru servisare. Asta de obicei e scris in specificatii. Daca e asa, n-ai ce face cu el.
